ABS speed sensor mounted on the rear differential part number
I am looking for the part number for the
[COLOR=black][FONT=Verdana]ABS speed sensor mounted on the rear differential for my 2000 Ranger XL 4x4 3.0 flex fuel model. I am also looking for the name of the part so I can look it up on the ford parts site. while looking I have found these names
ABS speed sensor
[SIZE=2]Powertrain Control Module<o>Speed Control Sensor</o>
<o></o>
<o>I had my truck in the shop and they did a health check, they found these codes po500 - cluster fault and the abs modual fault.</o>
ABS speed sensor
<o></o>
the trouble code is because the vss is bad. This is common. The part is cheap and the fix is easy. It literally is a 5 minute fix. 1 10mmm bolt and it pops off and you disconnect the harness. put some oil on the new o-ring and pop it in...makes sure you wipe clean the area around the sensor first........You did not say what tranny you have...on the 2000 the ecu gets the info from this sensor so it knows when to shift....
onequicksportster
1983 - 2012 Ranger & B-Series
07-08-2014 10:12 PM
