ABS speed sensor mounted on the rear differential part number
I am looking for the part number for the
[COLOR=black][FONT=Verdana]ABS speed sensor mounted on the rear differential for my 2000 Ranger XL 4x4 3.0 flex fuel model. I am also looking for the name of the part so I can look it up on the ford parts site. while looking I have found these names ABS speed sensor [SIZE=2]Powertrain Control Module<o:p>Speed Control Sensor</o:p> <o:p></o:p> <o:p>I had my truck in the shop and they did a health check, they found these codes po500 - cluster fault and the abs modual fault.</o:p> |
part # is F85Z-9E731-AB
SENSOR ASY (ABS DIFFERENTIAL) |
it looks like I am having a bit of trouble with the formating of my posts. sorry about the added crap in it
Thank You Very much for your time today. do you have any ideas about the error code po500 cluster fault
Originally Posted by lalamar
(Post 12169320)
P0500 IS THE VSS FAULT CODE ASSOSIATED WITH THE SENSOR YOU ARE ASKING ABOUT.
