Key & Cylinder Lock
Key & Cylinder Lock
Not the usual problem that you might think.
I pull into parking space and turn truck off. Key won't come out. Its a well used key so I figured that it was getting old and the cylinder was too.
So I go to Autozone and they have one replacement ignition cylinder lock in stock.
Go home, takes about 10 minutes to replace it.
Key will still not come out. You can start truck just fine and put it into the last position before the release/remove position and then it just stops. Obviously won't go into ACC position either.
Thoughts?
Thoughts?
That sounds like what normally happens if you try to take the key out while the truck is still in gear. Assuming it is an automatic, I would concentrate on the shift lever. Sounds like it may not be releasing the key when put in park.
Also try pushing the lever further towards "park" while you try turn the lock cylinder to the "release" position.
I fixed the problem but need to make it permanent with a part.
The nylon/poly sleeve between the shift u-holder and column assembly sheared off one end. There is still most of the sleeve intact.
However, the part that was sheared off was interfering with the shifter and the key release. I simply pulled out the sheared parts and its fine.
If you want to see the part...Pictures by braeburnucs - Photobucket
Now, to find that 4wd vacuum leak next......
Thanks.
Thanks.
Thank in advance for any advice.
Doug
Tritonstables
10-01-2021 11:46 AM
DoofusOfTheDay
13
12-12-2013 05:51 PM
