Ignition Switch
Ignition Switch
I thank you for the conformation on my suspicions, about my ignition switch being faulty. Now would you know where the switch is located? Also can I have it tested? Sorry Im just out of my element and need to do the work myself.
Its a 1990 F-250 Desiel
-Still Walking in Texas
on
You dont have to pull the dash. It is on top of the steering column about 3/4 the way down from the steering wheel. I think there are 2 7/16 nuts that hold it on (AN 11mm will fit also) I read one of your other posts... the switch is adjustable. loosen the the nuts, slide the switch and tighten. There is a part that goes from the lock cylinder to the switch that breaks sometimes, that could be your problem.
Received 3,114 Likes
on
all you really have to do to replace the switch is remove the lower dash covers(so you can see a little better) remove the fuse cover panel, and loosen the 4 bolts that hold the column to the dash. once loose the column will drop about 1 inch and you can reach in through the dash and replace the switch.
DGMFORD
03-24-2015 01:08 PM
Vincent Delpino
02-25-2012 01:31 PM
nuts4hotwheels
07-23-2005 11:42 PM
