03 Explorer Sport - P0171 Code...
Hello everyone, my Explorer CEL just came on today, when checked it only brought up a code P0171.
I have read through a bunch of the post and it seems most people get two codes where as I only get one.
Also most say their vehicles run rough, mine runs great, so I am at a loss as to what to check or replace first.
There does seem to be a slight ping when under load. Any help is greatly appreciated.
Thank You
Thank You
Hello again everyone, wanted to post again on my explorer and see if anyone might know what I need to do for pinging. As I stated in previous post, the pcv line was cracked and dealer replaced it. No CEL anymore, however, I still have the ping under load. Was thinking plugs and wires, but the vehicle only has 69K miles on it. Any suggestions?
Thank You
Thank You
gr97135. Thanks for posting what you found to be the problem to the code. I have the same code only for both banks. I will check this out first before I replace any gaskets.
The code all started from me trying to get rid of the pinging. I had pinging under load and decided to change the spark plugs. I think the driver rear cylinder plug was very loose, maybe hand tight. I have COP's, don't know if you do, so I didn't have any wires to change. I also put in a K&N air filter and cleaned the MAFS with the right cleaner. I also changed the fuel filter, which I think contributed alot to my problem because the fuel coming out of the "clean" side was brown. But doing this did get rid of my pinging, BUT now I have a P0171/0174 code.
skid809
03-16-2007 08:21 PM
smittyhines
01-25-2005 09:35 AM
bigmikeok
10-22-2004 10:28 PM
ttrolinger
11-07-2001 09:31 PM
