99 Explorer code question?
Old Jan 25, 2005 | 12:36 AM
smittyhines's Avatar
smittyhines
I have a 99 Explorer and the check engine light has been on lately. I had the codes pulled tonight and I was wondering if someone could tell me what they mean
P0306
P0171
P0174
Any insight that can be provided would be very much appreciated.
Thanks
Old Jan 25, 2005 | 09:35 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Assuming it's a 4.0 SOHC...?
306 = cylinder #6 misfire
171 = system lean, bank 1
174 = system lean, bank 2
Try changing the plug/wire on #6 (driver's side rear) to clear the PO306
The 171 and 174 are probably related, and are usually caused by a vacuum leak or dirty MAF sensor. You could have a leaking intake manifold gasket(s) causing the vacuum leak, very common on the 4.0. Try re-torquing the intake bolts first, see if that helps. If not, you may have to replace the O-ring gaskets.
