steering gear replacement
Old 08-07-2018, 10:19 AM
beartracks's Avatar
beartracks
beartracks is offline
Lining up my next victum. Bit of a problem to replace the steering gear because....
I'm working in a two car in use garage.
Truck has been lowered.
Has headers.
Don't have any help.
I'm old!
Anyway it's a pain getting it up high enough and working in tight spaces. Take it out the bottom or the top? Thinkin of using a ratchet strap around the booster to lower it out the bottom. Probably go with Red Head. Not sure about the ratio.
Old 08-07-2018, 10:41 AM
84espy's Avatar
84espy
84espy is offline
Found my thread of when I replaced it. I couldn't get it through the top. Because yours is lowered, you may want it on ramps so you can loosen up the pitman arm connection. Good luck.
https://www.ford-trucks.com/forums/1...ering-box.html
Old 08-07-2018, 05:45 PM
flatbedfordguy's Avatar
flatbedfordguy
flatbedfordguy is offline
Originally Posted by beartracks
Probably go with Red Head?
Might wanna give Blue Top a try. Both are quality rebuilds but Blue Top is typically 10-15% cheaper than Red Head. Same family just two different business's.
f250mtnbikr
1999 to 2016 Super Duty
09-06-2017 07:54 AM
99expyTN
6.4L Power Stroke Diesel
10-02-2014 08:12 PM
fordboy67
09-05-2013 08:24 PM
Quick Reply: steering gear replacement
