Red Head Steering gear
Old Jul 15, 2013 | 04:38 PM
fordboy67's Avatar
fordboy67
I know the Red Head steering gear is a popular upgrade. I'm looking into it and wonder how hard it is to install, and what price is a good price. Every time I do a search, my computer crashes. I'm sure it's my internet, but sorry if this has been covered.
Old Jul 15, 2013 | 06:51 PM
ScaldedDog's Avatar
ScaldedDog
Group buys on here will save you some money. The install isnt difficult, but can be a little messy.
Mark
Old Jul 15, 2013 | 08:38 PM
Tom's Avatar
Tom
The going price is around $350 plus shipping, and you can save up to $60 if you get in with a group buy. The job took me a couple hours taking my time, and it's not something that's terribly difficult.
I would not attempt this job without a good pitman arm puller and impact wrench. Without the impact wrench separating the pitman arm isn't something I would be willing to tackle!
Old Jul 15, 2013 | 09:25 PM
wpnaes's Avatar
wpnaes
Agree, but don't let that stop you. I used hand tools only. The local Napa removed the pitman arm and steering pump pulley (might as well replace the pump and hoses while you're down there making a mess).
Old Jul 15, 2013 | 09:31 PM
Tom's Avatar
Tom
Now there's an idea Sean! So I'll amend my previous statement: Don't attempt to remove the pitman arm with hand tools!
Old Jul 15, 2013 | 09:59 PM
sammie0126's Avatar
sammie0126
Not that hard to do...here is a write up on it for V10's followed by one for Diesels above the original post.
https://www.ford-trucks.com/forums/1...r-dummies.html
Old Jul 15, 2013 | 10:03 PM
amsk8er1983's Avatar
amsk8er1983
Not hard to install took about an hour and a half there is a great write up on this forum on how to do it. Paid $350 with a $175 core but make sure you keep checking your bank account took about six weeks to get my core back.
Old Jul 16, 2013 | 04:34 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
I thought I would never get the Pittman arm off of the old steering box! Definitely needed a big puller, impact wrench, and heat.
Other than that it's not a bad job to do. The results are profound. Well worth the expense.
I changed the ball joints AGAIN (Moog this time) and re-greased everything under the front end. One item I had missed before was the wheel u-joints. Since they are directly in line with the pivot axis of the front wheels, this made a huge difference too. The u-joints were in good condition but were stiff. This added to the stiffness in turning and lack of steering wheel returning nicely to center.
I also changed the caster bushings while in there. Added some positive caster. Now it drives like a champ.
While trouble shooting steering issues I disconnected the steering damper. I have not reconnected it and will not.
Old Jul 16, 2013 | 07:20 AM
fordboy67's Avatar
fordboy67
Once it was installed, did any of you have to adjust it or was it basically plug and play?
Old Jul 16, 2013 | 07:59 AM
wpnaes's Avatar
wpnaes
Plug and play. May have to adjust the tie rod collar (see pic above) to get the steering wheel centered, but no alignment needed.
Old Jul 16, 2013 | 09:53 AM
TheBestKindOfEX
plug and play
Old Jul 16, 2013 | 04:20 PM
Kdr358's Avatar
Kdr358
Just replace the Pittman arm. If you live in the rust belt then just order a new one and start fresh.
Old Sep 5, 2013 | 02:46 PM
ithaca1230's Avatar
ithaca1230
When is the next group buy gonna happen? I think I'm ready for one.
Old Sep 5, 2013 | 03:13 PM
Magnus E's Avatar
Magnus E
Check the SuperDuty forum for ongoing group buy of red head box. We need at least one more so join in!
Old Sep 5, 2013 | 08:24 PM
double ott ex's Avatar
double ott ex
here is the current group buy thread. in its second generation I might add.
https://www.ford-trucks.com/forums/1...oup-buy-5.html
on the first buy in that thread, I took my gear off and drove it down to red head and said give me one of these. I do like living in seattle!
DOE
insurr3ction
Dec 1, 2018 12:53 PM
scatgo
Jul 2, 2010 06:56 PM
pedrorairez
Feb 25, 2009 01:04 PM
zfifty
Dec 5, 2006 09:20 AM
jak1212
Nov 27, 2001 03:47 PM
