Pillar pod gauges for gasser???
Hey yall i was thinking of getting some Dual pillar pod gauges for my F250 351w. The only thing holding me back is you dont see many gassers with gauges, i see alot of diesels but not gassers. I really just want it for show and my taste, its probably gonna be a water temp and volt gauge. So the question is, is it weird to have gauges on a gasser? http://www.lmctruck.com/icatalog/FD/full.aspx?page=100
Agreed they add function as well as form. Id do oil pressure and/or trans over volts... I have 3 in place where the ashtray was but they are mechanical (hose and tubing behind them) so A pillar is not a option. Yet, Id love them there and just may add them in the future! ( also 351 )
Ya thats why i say, but i rarely find a gasser with pod gauges, unless its a lightning or supercharged truck. There common for diesels
You can have both working. Unscrew the stock oil pressure sending unit from the block and replace it with a short pipe nipple with a T fitting attached to it. Then you screw the stock sending unit to one side of the T and the new sending unit to the other side. I forget what size pipe it is (1/4" maybe) but it's just standard plumbing pipe you can get at your local hardware store or Home Depot, etc.
