E4OD compatability
on
As long as the '97 is for a small block motor(4.9,5.0,5.8) and not from an OBS big block(7.3,7.5) or newer modular(4.6,5.4) truck. Incidentally have you done full diagnostics on your truck to ensure it's not just a sensor issue, for example hard/late shifting or intermittent neutrals is not a trans problem so the issue won't be cured with a replacement. Just saying because it's a lot of work only to find out the PSOM or TPS is the real problem.
on
That's from a first generation 4.6 powetrain then which apparently uses the same trans bolt pattern as the pushrod windsors, but I thought all those trucks had 4R70W trasnmissions. I could be wrong there but that's something you're gonna have to check out, these are both electronically controlled gearboxes but they're not directly swappable, there are wiring and control(computer) differences. IDing the trans is pretty easy, the 4R70w oilpan is shaped just like an AOD while the E4OD oilpan is totally different, see below...
javi2001
08-23-2005 10:38 AM
rancherman84
01-17-2004 03:09 PM
