Pulling the engine without removing the front clip?
I dropped a 460 into my F150 in place of the original 300 Six and I did not pull the front clip. I have never pulled the front clip for any engine removal. It goes in fine, you need to kind of turn it cockeyed a bit to clear everything going in. I used a roll-around engine hoist, not an overhead. I did take off the front tires and lower the front end on my lift so I would not have to jack the motor so far in the air.
side question... did you get the 460 to smog after this swap?
Number4
21
11-10-2018 02:24 PM
ktm4012
11-04-2017 06:56 PM
