2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Ford Tech Help Needed '07 Expedition Multiple codes
Old 06-28-2012, 07:00 PM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
2007 Expedition 70k miles. Friend purchased from dealer and before veh made 2 miles the wrench on dash came on, check engine light, it went into limp mode.
I cleared codes and it was good for about 2wks. multiple codes now
Veh cuts out, gauges go all over and read wrong, speedo quits, goes into limp mode. Shut veh off and it did not want to restart. Cleared codes and it started but went into limp mode, seems like all modules, computers and dash are losing power intermittently.
I am curious if someone has ran into this issue. Seems to me its a loose or partially broken wire or possible computer itself. In all my years of messin' with fords I have changed ZERO Computers.
Partial List of Codes
P1500
P1000 KNOW THAT ONE
U0155
U0101
U0100
B2916
B2917
U0121
U0151
U2199
U2023
U2471
B2293
U1900
I think its all pretty much related because of a power loss of sorts...
Just so it is clear I can look up codes but wondering if others have seen same issue with so many multiple codes that seem related to power failure.
Old 07-24-2012, 08:23 PM
Boss9F100's Avatar
Boss9F100
07 Codes
Anyone with ideas? A month later and still not fixed . . .
So far all connectors have been taken apart and pins inspected, all grounds inspected & cleaned, inspected wiring harness but of course did not remove.
The IC
ABS
Trans
and all other modules lose power at approx the same time.
1st thing noticed is the power to test port so any diagnostic device loses power then the speedo starts bouncing the wrench light comes on, abs light, check engine, trans will no longer shift and the engine goes into limp mode, the A/C system shuts down.
It only does it when things are warm/hot never cold. Runs absolutely perfect until this happens. Even the fuel mileage is incredible... until things go south.
Yes, The PCM has been replaced. Unable to do a computer module software upgrade because with this model it cannot be done until it has completed a full drive cycle. It has never completed a full drive cycle. 6 of the 7 parameters only. Mostly because it takes that much longer here when the ambient temp into engine is over 100.4 deg f
Old 07-27-2012, 11:27 AM
function12's Avatar
function12
function12 is offline
Sounds like a short in a wring harness somewhere.
Old 08-30-2014, 01:23 PM
Hdhunter's Avatar
Hdhunter
Hdhunter is offline
Trailering
I know this is an old thread but I too have a 2007 Ford Expedition, mine is an Eddie Bauer, 2WD 5.4L with 11000 miles on it and I am experiencing almost the exact same problems. I have mine in at a Ford dealer for 9 days now and they can't seem to find the problems. Mine is throwing codes U0001, U0100, U0121, U0155 and they've replaced the ABS module and ran up an $1100 bill and nothing.
Let me know what if anything you found out!
Old 08-31-2014, 01:26 AM
gwcloud's Avatar
gwcloud
gwcloud is offline
I doubt if this could help but ........
How about starting at the scource close to the battery. Is there a system fuse right near the battery?
Richard
2007 Navigator
strokenboost
Modular V8 (4.6L, 5.4L)
08-22-2016 09:49 AM
reynolds357
1997-2006 Expedition & Navigator
15
10-07-2010 10:02 PM
swtsolutions
02-25-2007 06:36 PM
tplanz
01-25-2005 11:17 AM
nugy88
04-12-2004 10:44 PM
Quick Reply: Ford Tech Help Needed '07 Expedition Multiple codes
