Barometric pressure sensor?
Old 06-26-2012, 05:06 PM
Ken_C's Avatar
Ken_C
Ken_C is offline
Where is this sensor located? anyone got a picture? do they go bad? I was just wondering because ive noticed sometimes on a hot restart I get glowplugs coming on? not a big deal i guess. more of a curiosity. would it throw a code? iguess if I had AE i could figure it out. but my laptop runs ubuntu linux. they should make it operating system independent. like have its own OS on the cd which could be bootable?
Old 06-26-2012, 05:23 PM
fordpride's Avatar
fordpride
fordpride is offline
It's under the dash by the stearing column it looks like a relay plugged into some wires
Ken if you wanna try one before you go but one shoot me a pm with your address. I have a good used one I'll ship you and if it fixes issue you can have it. If not mail it back
Old 06-26-2012, 05:46 PM
fordpride's Avatar
fordpride
Could be EOT sensor
Ohm the sensor when engine is cold
K Ohms__Volts____TempF___Temp C
826______4.75______-32______-36
785______4.75______-30______-34
575______4.73______-22______-30
525______4.72______-20______-29
365______4.68______-10______-23
300______4.65______-4_______-20
250______4.63______0________-18
192______4.6_______10_______-12
173______4.55______14_______-10
139______4.49______20_______-7
103______4.4_______30_______-1
98_______4.38______32_______0
64_______4.18______40_______4
59_______4.13______50_______10
43_______3.92______60_______16
37.3_____3.8_______68_______20
33.6_____3.73______70_______21
26.8_____3.53______80_______27
24.3_____3.44______86_______30
21.5_____3.32______90_______32
17.2_____3.08______100______38
16.1_____3.01______104______40
13.9_____2.84______110______43
11.2_____2.59______120______49
10.9_____2.56______122______50
9.34_____2.38______130______54
7.55_____2.11______140______60
6.28_____1.89______150______66
5.34_____1.72______158______70
5.32_____1.71______160______71
4.48_____1.52______170______77
3.84_____1.37______176______80
3.75_____1.35______180______82
3.17_____1.18______190______88
2.8______1.09______194______90
2.68_____1.04______200______93
2.2______0.88______210______99
2.08_____0.86______212______100
1.87_____0.78______220______104
1.56_____0.67______230______110
1.33_____0.59______240______116
1.19_____0.53______248______120
0.38_____0.17______CEL Below This
__________________
Old 06-26-2012, 06:24 PM
Ken_C's Avatar
Ken_C
Ken_C is offline
Just ordered a new Low pressure oil sender. F6TZ-9278-AA. mines leaking and making a dirty mess of the HPOP res. I will let ya know on the BARO. i have the front diff leaking around a couple bolt heads to worry about. i had to drive over a curb to avoid killing an idiot who started to turn left in front of me then changed her stupid mind and stopped right in front of me. since then the front diffs been wet with gear oil.
Old 06-26-2012, 10:16 PM
fordpride's Avatar
fordpride
Offer stands just let me know off you want it. It's free
Old 06-26-2012, 10:17 PM
Talyn's Avatar
Talyn
Talyn is offline
Gp's will always come on no matter what.
Just depnds on how long.
Old 06-26-2012, 10:18 PM
fordpride's Avatar
fordpride
Mine doesn't come on when up to temp.
Old 06-26-2012, 11:48 PM
nomad221's Avatar
nomad221
nomad221 is offline
What is the cutoff temp ?
Old 06-27-2012, 05:19 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
Mine don't come on either when up to temp. I think I read when the motor is up to 160? Can't remember for sure the temp.
Old 11-22-2012, 09:26 AM
TreesnFords's Avatar
TreesnFords
TreesnFords is offline
I am having similar issues. I just tested the eot. motor cold (around 50 deg F) ohms 77.8, volts 4.76. It does not really match up to the chart so not sure what to make of the sensor. Any thoughts?
Old 11-22-2012, 11:52 AM
Hussler's Avatar
Hussler
Hussler is offline
About 135* F.
new2diesel
04-03-2011 05:04 PM
sawtooth
6.4L Power Stroke Diesel
12-12-2010 07:15 AM
daner01
09-27-2010 12:13 PM
brad7.3
08-20-2006 09:37 PM
Rbomar
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
05-11-2004 11:07 AM
Quick Reply: Barometric pressure sensor?
