Oil Pressure Sensor..
Old May 10, 2004 | 08:09 AM
Rbomar's Avatar
Rbomar
Where is the oil pressure sensor located on a 95 4.0 Explorer and how hard is it to change?
Thanks !
Old May 11, 2004 | 11:07 AM
Rockledge's Avatar
Rockledge
Left (driver's) side, front of the engine block. The sensor is actually attached to a small adapter, and the two of them together form a 90 degree angle. If you look under your truck from the front you should be able to see it. Not hard to change, but make sure you use a little pipe sealant/teflon tape on the threads of the new sensor.
