460 intake torque specs?
Old 06-24-2012, 06:25 PM
Norton72's Avatar
Norton72
Norton72 is offline
Arrow 460 intake torque specs?
I looked in my 1976 Ford shop manual and there are no torque limits specified for the intake manifold. It is listed, right next to Exhaust, but it is blank. Further down the page there is a table for "Torque Limits for Various size Bolts-FT. LBS. The bolts are 9/16 heads and the shaft is about 5/16 best I can figure. The value for 5/16-18 bolts is 12-18 FT. LBS., does this sound right? I would think it would be more, but when I took the intake off the bolts didn't seem to be very tight at all, so maybe this is right.
Three of the four corner studs came out with the nut, so I cleaned them up, checked the threads and put the studs back in with red Locktite. One of the bolts was actually a stud with a nut on it, and one of the other bolts was of the wrong type. Tomorrow I will see if I can find two replacement bolts and then hopefully I'll be able to wrestle the intake back on tomorrow evening.
Old 06-24-2012, 09:00 PM
Norton72's Avatar
Norton72
Norton72 is offline
25-30 ft. lbs. with light engine oil seems to be the average consensus based on several innerwebs resources.
F-250 restorer
08-02-2013 01:43 PM
79_250RangerLariat
12-17-2005 11:01 AM
greybullit
07-21-2005 05:34 AM
ColonyPark
07-03-2005 12:56 PM
mcaldj25
09-21-2002 08:55 PM
Quick Reply: 460 intake torque specs?
