Torque specs???
Old Jul 20, 2005 | 06:34 PM
greybullit's Avatar
greybullit
Torque specs???
I just installed a new intake manifold on my 75 F250 with a 360. I was wondering if anyone knew what the intake bolts should be torqued down to? Also since I had to take the rocker arms off to get the intake off, what should I torque the rocker bolts down to? Any help would be greatly appreciated! Thanks
Old Jul 20, 2005 | 11:08 PM
bshackelford711's Avatar
bshackelford711
is the motor in the truck? If it is use a hoist to lift the intake up and on the motor. trust me on this i put one in a 68 f-100 and pulled my back. I was not using a hoist, I dropped the gaskets and it was such a mess trying to move that heavy thing.
is the intake the old iron intake or new aluminum?
If i rember right the intake is 25lbs ( i might be off the wall on that one but i think that was right) start to trq the middle bolts first working your way out in a criss cross pattern. ( you dont want to warp that thing) The back to bolts are the short bolt. You might not be able to get the back bolts started until you start to tighten the other bolts but that is ok. just tighten the others up until you are able to get the back ones started.
the rocker bolts should be trq to 45 lbs. ( only about 1 turn each all the way down the line until you get to all of them trq to that spec)
I hope that helps and that someone can verify that they are the right numbers.
Thanks
-Brandon-
Old Jul 21, 2005 | 12:22 AM
Bear 45/70's Avatar
Bear 45/70
Intake is 45 ft-lbs. The rocker stands are the same. And real mean (well young and stupid man) just set the intake on with one hand.
Old Jul 21, 2005 | 05:34 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Aluminum intake 25 ft lbs
Iron intake 35 ft lbs
G.
carl2591
18
Sep 8, 2015 08:24 AM
kevinclark1990
Jun 2, 2015 06:14 PM
brokeasajoke
Dec 16, 2014 09:43 AM
ol-blu
Apr 11, 2012 07:28 PM
Gidde Up
Apr 19, 2003 09:38 PM
