Brake performance...
.. For those that haul or tow heavy. Returned from our trip last friday and I am disappointed with the pads that are on it now. Lackluster stock pads and rotors. Some of those downhill runs were nerve racking to say the least, and stop and go traffic in some areas I could feel them fade. With the camper on I'm around 11,700 lbs or so. I've seen the adds for Hawk pads and such and just wondering who's running them and do they live up to there claims.
Thanks, Bill
Thanks, Bill
on
1 Post
Thanks, Bill
Thanks, Bill
For rotors you do not need cryo, drilled or slotted rotors. Absolutely stay away from drilled rotors! Just don't go cheap and get a quality rotor. If you have the ability, a critical step that gets way overlooked by consumers and mechanics is to use a dial indicator to make sure the rotor is mounted within the runout specified in the service manual, 0.0015". Lower the better which can often be achieved by indexing the rotor.
While the Hawk LTS are very rotor abrasive, if the installed runout is excessive you still run the risk of developing thickness variation in the rotor which will cause pulsation when braking.
For you I would not screw around with any other pads.
Just got to my mechanic that's going to put my rotors on. I was talking to a motor craft guy there about my cheap rotors only lasting. 4k miles. He walked off and talked to the owner of the place. The owner came back and said he was going to swap my 30 cheap rotors for motor crafts free of charge. You can't beat that for service!!!
Riffraff Diesel: SSBC Quick Change Front Caliper Kit
Riffraff Diesel Performance Parts: - EBC Brake Pads
Yes, I put in a non-EBPV pedestal over the winter and dearly wished I had that mod on this truck. Gonna rebuild the old one and put it back in just for that purpose. Had it on the nephews truck and mountains were never an issue and it being a stick shift, you could use it easily.
