Machining 6.0 heads
Old 06-18-2012, 08:48 AM
Firemudder's Avatar
Firemudder
Firemudder is offline
Machining 6.0 heads
I'm about to have new gaskets put in my truck since the BO blew and am going to get the heads machined. What's the most that can be taken off these heads?
Old 06-18-2012, 10:44 AM
bismic's Avatar
bismic
bismic is online now
Received 2,517 Likes on 1,749 Posts
Many people say no more than 0.008. I am probably even more conservative at 0.005. Then there is also a lot of discussion that a better measurement would be to stay with a MINIMUM head thickness is 3.74 inches. Get them to a tolerance of 0.002 of better.
Old 06-18-2012, 11:19 AM
Firemudder's Avatar
Firemudder
Ok great thank you very much.
Old 06-18-2012, 12:13 PM
Firemudder's Avatar
Firemudder
What's the recommended torque for the studs. I know it says 210 but is the old 245lb ok to use with the new lube?
Old 06-19-2012, 04:40 PM
Firemudder's Avatar
Firemudder
Anyone have any input on the studs?
Old 06-19-2012, 09:20 PM
bismic's Avatar
bismic
use the new lube (don't be stingy) and torque to 210 per instructions (IMO anyway)
Old 06-20-2012, 09:44 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
Yep, 210, follow the instructions.
Old 06-20-2012, 09:54 AM
tex25025's Avatar
tex25025
tex25025 is offline
I have to 3rd that on the torquing instructions and I also want to reiterate the .005 on the machining the heads part of it as well.
Make sure you that are going to a competent shop as well as that can really make or break how successful you are in this.
Old 06-20-2012, 10:11 AM
Firemudder's Avatar
Firemudder
Thanks guy. Yeah I'm taking the heads to a well know shop that does these heads often. I will for sure use the directions and go 210.
Mike in Arizona
02-27-2020 08:39 AM
CountryMonkey07
01-20-2018 08:39 AM
6.0's rock
1999 to 2016 Super Duty
05-02-2016 01:34 PM
Shaneb75
01-02-2015 11:20 AM
olfordsnstone
07-06-2013 08:06 PM
Quick Reply: Machining 6.0 heads
