Reading transmission fluid level?
Does anyone else find it difficult? Motor oil is easy, the line is plenty visible. However the level on the dipstick for the transmission doesn't seem to be distinct.. I changed the filter and gasket and drained the fluid from the torque converter and have put in about 10.5 quarts of fluid. I didn't disconnect the cooler lines but I changed the filter parked slightly uphill so maybe most of it drained too?
Am I doing something wrong or do I not have enough fluid if the line is not distinct? I see fluid on the dipstick but checking with the engine running I can't tell if it is fluid that just splashed up high on the stick or what...
I'm not sure what tranny you are working with but the C6 takes about 12 quarts with the T/C. I ended up putting almost 13 in before it was where it needed to be. For a 4X4 it calls for around 13 quarts. The AOD is in the same neighborhood.
I was having trouble finding my level at first too, then I realized I just didn't have enough in there.
If you are adding fluid, you have to wait a few minutes for all the fluid to drain down the tube, or it will mess up your reading on the dipstick. Wait a few minutes, pull the dipstick out and wipe it off with a rag, and then stick it back in and then pull it out again. Twist the dipstick so you have a glare on it, and you can see the fluid will look shiny where the bare dipstick will look dull.
I'm with you - clean ATF is very difficult to see on the dip stick. But, I was able to see it in direct sunlight on the pickup. However, on my wife's Subie I never did find it. Yes, there was lube on the stick but no line. I can see it cold w/o the engine running but not with it running, and there is no mark for cold/not running. I finally gave up and decided it had to be right as I put the correct amount in.
Thanks for the input.
I never worried about the cooler and the lines, and it always still took almost 13 quarts when I drained the converter.
Always go by the level where the fluid goes all the way across the dipstick. A little bit of fluid higher up, but only on one side is just where it's rubbing along the dipstick tube.
Same here, last time I drained the tranny and TC, I also did not drain the lines or cooler and it took 13 quarts.
Also common somewhere along the line for someone to have installed a deep pan, which will add another coulple quarts if that was done.
brooklyn
20
11-10-2019 11:29 PM
rogersdan
08-02-2013 02:56 PM
79BRNC
09-17-2008 12:04 PM
