Speedo Wacko
What truck? If it is the 89, I was under the impression that they still had mechanical speedometers. Possible broken drive cable?
The cruise control gets an input from the speedometer; so if it is bouncing around, guess what the cruise does.
If you have an electrical speedometer like on the 93-96 trucks, it is probably either the VSS mounted on the rearend or the PSOM itslef.
Robert
Robert
on
You just pull the cable itself out of the jacket from inside the truck, that is why you remove the speedo. Then slowly slide it back in using wheel bearing grease on your fingers to put a coating on the cable as you slide it back in.
You do not pull the entire dash, just the instrument cluster.
Pull and clean the sensor, a new sensor is about $10-15 at the dealership, if the sensor doesn't do it then it's the PSOM, one word of caution, if you peg the electric speedo it will mess up the PSOM and cause the bouncing issue, go ahead and ask how I know.
I replaced the sensor in the rear end on my 92' and it's a hell of a lot worse then it was before I replaced it!
The speedometer starts twitching soon as I start driving and will not stop. I think I have a wiring or a connector issue. Going to play around with it to see what happens. Take some brake cleaner and clean the connector best I can to see if that helps. Then I will go from there.
My truck did the same thing, and most gear drive speedometer fords do it. A quick fix for it is to ziptie the cable that the gear is on to the crossmember and get the gear on an angle so it grabs. Kinda have to ziptie it tightly. The other fix is to buy a new gear of course. I have mine ziptied up and haven't had an issue in 2 years and 10k miles.
Not to thread hijack, but a bouncing PSOM equipped speedo can be caused by the ABS brain too. My speedo took a dump one day and I spend a week chasing it. Troubleshooting until I was sure the PSOM was bad, so I replaced it. Then I tried a new VSS just in case.
The schematics show the only other thing on the VSS signal circuit is the ABS brain. Unplugged it... = problem solved! Tried another one from the junkyard, still no good.
My solution... who needs ABS anyhow? I grew up driving without it, I certainly don't need it now!
lildrummer420
10-11-2011 10:55 PM
evin
04-28-2004 05:52 PM
redneckdieselmechanic
03-24-2002 09:55 PM
