Tech folder format suggestion
#46
Bump....
https://www.ford-trucks.com/forums/1...l#post11898840
This is a reminder... if you find any write ups that we need to add to the NEW Tech_Folder Layout reply to this thread with a link. Remember that it must be X specific (only in an X) or written from an X owner. Thanks for the help improving our technical abilities.
#47
Any progress on the "More User Friendly Tech Folder", Stewart?
Ford Links Specific To The Excursion
Engine Modifications and Articles
Exterior Modifications and Articles
How To Search Ford Truck Enthusiasts Excursion Forum with GoogleInterior Modifications and Articles
Misc Modifications and Articles
Suspension, Brakes & Wheel Modifications and Articles
Dimensional Data
2002
2002
Tech Folders
5.4L V8 Gas
6.0L V8 Diesel
6.8L V10 Gas
7.3L V8 Diesel
And don't forget the Articles Section
5.4L V8 Gas
6.0L V8 Diesel
6.8L V10 Gas
7.3L V8 Diesel
Exterior Body
Excursion Roof Rack Modifications
Lighting System Changes and Cosmetic Lighting Modifications
OEM Fog Light Mod for Early Excursion Models
Electrical Related Modifications
Door Lock Repair
Crime Prevention / Excursions
Help with heated seats
Fixed my OD switch SHORT
Window Motor Replacement
Interior Components
Door Lock Actuator Replacement Procedure (Enhanced)
Rear hatch latch assby replacement "how to" w/pics
Rear Hatch Door Lock Actuator
Rear Hatch Lift Supports
Swapping out the 2nd row bench for captains chairs (Bench to Buckets)
2nd Row Seat swap info: (Bench to Buckets)
08-12 Crew Cab Front Seats Into Excursion
Blackwood Steering Wheel Install
Navigator Steering Wheel Swap for Non-Redundant Control Ex's: How-to
Gear Shift Linkage Adjustment
Audio & Video
Component and Door Speaker Writeup
Door Lock Repair
Interior Components
Audio & Video
Misc Components
How To: Retreive your door code on 02+ excursions. NEW EASIER METHOD!!!
Keyless entry code (instructions and string) 2002+
Braking Components
Excursion rear brake pad change with pictures
Wheels & Tires
Spacers
Suspension System Components (lift kits, shocks, etc)
Detailed Shock Install Procedure
Comprehensive "Steering Wander" Thread Compilation
Front Sway Bar Bushing Replacement (with pics)
How To: Replace Rear Wheel/Hub Bearings
Ball Joints - 2wd - Parts Listing
V/Modified B codes, step-by-step
Steering Wander Thread
Wheels & Tires
Spacers
#49
Dimensional Data
2002
2002
Tech Folders
5.4L V8 Gas
6.0L V8 Diesel
6.8L V10 Gas
7.3L V8 Diesel
5.4L V8 Gas
6.0L V8 Diesel
6.8L V10 Gas
7.3L V8 Diesel
Exterior Body
Door Lock Repair
Interior Components
Audio & Video
Door Lock Repair
Interior Components
Audio & Video
Misc Components
Braking Components
Wheels & Tires
Spacers
Wheels & Tires
Spacers
#52
You guys have done a lot of the work for me, thanks!
I'll take the formatting and suggestions and tweak them a bit and get the tech folder redone shortly.
Thanks for the help guys, it's really appreciated! And just a reminder, if anyone has a suggestion for a thread to be added to the folder, PM the link to either me or Tor.
Stewart
Stewart
#54
Stewart
#55
I did also figure out that the forum software does not allow a simple cut and paste with links, so I know now that it won't be a simple cut and paste which is probably why the "old" tech folder looks so bad. When you get around to it, if I can help, I will. I have done a lot of html coding.
gangstakr
04-14-2016 02:31 PM
