Cost of having the oil pan gasket redone?
I have heard the stories of pulling the motor to do this, but I believe it needs it. I stepped on it coming home tonight and noticed that almost immediately after pulling into the driveway I had a few fresh drips so I looked underneath and saw fresh build up around the pan lining.
So who has had a shop do this and what have you guys paid. Thanks in advance.
on
Don't fix anything that ain't broke! Get under there at the quarter car wash and clean that area and above it, then look again after a hundred miles. If you really want to find it put some dye in your oil. If it is the pan (random pan leaks are rare), tighten the bolts on that side first (don't break any), and look again after another 100 miles. Lower (appearing) leaks usually originate higher up.
Good idea, Brent!
Stewart
Ive used tracer before in other vehicles... not sure how much would be sufficient for a 6.0.
Amazon.com: Tracer Products TP34000601 UV Fluorescent Leak Detection Dye - Set of 6: Automotive
I also would try to tighten the bolts over time they come loose. I had an oil leak I thought was a rear main seal, it turned out to be the rear most oil pan bolts were about 1, 1/2 turns loose! I had the shop that did my injectors tell me that the oil pan was replaced recently hence no rust on it! I would first see if it is the pan bolts. Also the mechanic said usually he would charge about 600 - 800.00 for an oil pan job simply because the only way to do it is pull the engine. There is a video of a guy replacing his on youtube on a 99 F350 Oil Pan Replacement Ford F350 Powerstroke 7.3L Diesel - YouTube
on
Power wash won't hurt it there, in fact I spray my v-10 with degreaser and power wash it once in a while avoiding sensitive areas but never have a problem. All my cop boots are sealed at the top also. I haven't used tracer dye for a long time.
5speedahead
29
03-11-2017 07:38 PM
