I have replaced my oil cooler and did two complete flushes of my system and I'm still getting a high delta spread ect194 eot 204-208. I am stumped. I did do a egr delete as well and have heard that I can get away with a higher spread???? Any ideas?
What are your cold soak numbers? Could be a bad temp sender. Try swapping them.
When you flushed the system did you do a before and after VC9 flush? 10* split not bad. Why so much variation on eot? Hill climbing / towing doesn't count.
My cold soak numbers are the same may be off by 1 degree sometimes but normally the same. When i did my flush I used vc-9 then flushed with distilled water. At one time I saw 16 degrees difference on the high way, as soon as I get off the freeway my eot's come down! I guess I can try swaping the sensors and see what happens. Do you know where these two are?
So you think I should do another flush? Coolant is starting to get $$$$$... no I didn't get a cel light , oh and i just passed emissions today!!!! Stupid DMV lol
Did you change the oil cooler yourself? the EOT sensor is right on the oil cooler, the ECT is on the driver side close to the radiator below the thermostat housing. Both are in tight space to get tools to.
There can still be a bias of a few deegrees, but typically not more than that.
Personally I don't think you have an issue worth worrying about at this time.
That is great to hear, but I'm just worried about these two temps I have read so much bad and good on them so i want to really watch them!! So even with a almost 15 degree spread I shouldn't worried to much??
Bismic,,,,,,, just so we are on the same page, you are saying I shouldn't be to concerned till around 220 EOT'S.right? Not to sound stupid or keep bugging you I'm just so freaked out with these 6.0's. I love the truck and want to make it last as long as I can!! What if I'm at 210 ECT and i hit 223 or so EOT'S. Just hypathetcally.... am I just reading to much into this??
IMO the most important reading when you have an EGR delete is the raw oil temp number. Yes if you see a 15 degree spread you are plugged to a slight degree (on the cooling water side of the oil cooler), but it is not a major issue as long as the oil can get adequately cooled.
