Sealed Headlights to composite
I have a 2004 E-250 van, is there anyone out there that can help with part numbers or where to go for parts for this conversion. the wiring harness and the brackets that hold the composites to start then I need the screws and the for the corner lights. etc etc etc
What prompts this change---what do you hope to achieve?
I have a crash book that I can pull all the Ford part numbers you'd need----the header panels are the same whether sealed beam or composite so fit wise this should be an easy swap---if you don't count the expense of the composite headlights that is. Lots of downsides to this IMHO, others will disagree but I'd suggest you start noticing other vehicles with these headlights---they all tend to discolor and turn yellow after a short while, the cheaper the units the quicker this happens. Its not reversible since some of this occurs inside the housing and is unavoidable.
Anyway I can help with your part numbers and there is thread here on FTE about upgrading the wiring for this sort of conversion. Glad to help if I can!
Welcome to FTE BTW!
Welcome to FTE BTW!
the sealed beams in my trucks have always been enough. are yours properly aimed? poorly aimed lights produce horrible visibility, and often blind drivers in front of you
assuming you want to swap anyway, another low-cost option is a composite headlight unit that mounts just like your sealed beams. installation is just like changing a sealed beam headlight, and these units recieve a halogen bulb just like composites.
Josh is onto something and there was a thread in this forum with eBay links to those halogen/composite units---it would be the less expensive way and far far far easier to change too!
Here's a few links of this type of conversion: https://www.ford-trucks.com/forums/1...eadlights.html, specifically post #8---follow that link.
Another thread to improve factory wiring for halogen lamps: https://www.ford-trucks.com/forums/1...-for-30-a.html
Hope any of this is helpful!
I have a scanned image of the parts breakdown for the h/l units and all attaching hardware. It might not display clearly here due image size limits, trying anyway:
If that's not helpful try the full size image:
http://s184.photobucket.com/albums/x268/JWAPhotos/
Find the image, click on it and then click again for the largest view possible there.
Hope that's more helpful!
Yes, w/o a doubt "others will disagree" & should. Let's stimulate objective discussion of the advantages of FORD's Aero-design headlights & attempt to set the record straight.
Wonder if anyone's opinion will suggest the light output of FORD's Aero headlights, when compared to stock sealed beams, is among the "downsides"?
Wonder if FORD's Aero headlights were named for their small, but significant, aerodynamic advantage?
Wonder how many "will disagree" w/the notion FORD's Aero headlights look better than stock sealed beams?
Wonder if the crystal clear original Aero headlights on my '92 Club Wagon & '98 F150 are aberrations to the claim "they all tend to discolor and turn yellow after a short while"?
Wonder if ads for plastic headlight treatments/polish are all rip offs & if even slight discoloration/yellowing from harsh detergent washing/chronic pollution is "not reversible"?
IMHO when dmustang said: "A frontal collision for one and a lack of vision at night for the other. I've tried the newer silverstars with a little better results but I need more." it made his E250 an excellent candidate for Aero headlights. Am confident he's already noticed Aero headlights on "other vehicles".
IMHO the only "downsides" thus far seem to be the relatively high cost of new FORD parts. This might be averted if insurance is involved & some liberty can be taken regarding P/N's. If not, I'd suggest combing self serve recycle yards for a good set of used Aero headlights. The swap itself is quite "simple" & "the corner lights" are the same. The biggest issue is splicing in headlight plugs.
Did my image or link to the part numbers help in any way?
Yeras ago I had a 90 Dodge van and I wasn't happy with the stock headlight output.I installed Hella replacement units that used H-4 bulbs.The glass is far superior to OEM and they could be lamped with an assortment of wattage sizes for output. The normal is 55/60(or something like that). I had 55/100 bulbs in them.In tne 17 yrs I ran that van,I was never stopped for any infraction regarding the lights.The beam pattern is far superior to any OEM.and you dont have to do major changes to the body panels to get them to fit.They just replace the stock ones.Because of the extra amps required for the hi-beams, I used relays to switch them. Rick
IMO = A simpler and less costly option could be the Hella and Cibie "european" sealed beam headlights (with the H4 bulbs) as noted. I have been using these in many of my cars since the mid-70s. Theye provide a much superior beam patterns vs. standard sealed beams and at least as much if not better light than the newer Aero lights for visibilty.
Good luck with whatever the choice.
fordboy300
20
09-12-2011 02:55 PM
