Changing ignition key cylinder on F-6
Old 07-19-2014, 09:08 PM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
The F-6 I acquired lately did not have a key so I ordered a new tumbler with keys. I changed my F-1 without any problems but the F-6 old switch doesn't seem to have a hole in the switch body to where I can depress the plunger to release the cylinder. I see a small horizontal hole but none on the horizontal switch barrel like on the new ignition switches have. I also don't have a key to turn the old tumbler to get it in position to pull it out.
Any ideas?
TractormanBill
Old 07-19-2014, 10:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Mine had a brass peg that I thought was a plunger, but was a peg that had to be pulled out. Worst case, to get it turned, slide the spring retainer off -- all the springs and plungers will pop out, you can then turn it with a screwdriver.
93Sunplex
02-27-2007 06:17 PM
krautwolf
02-08-2005 06:33 PM
opi8
45
08-30-2004 07:26 AM
capn
10-27-2002 04:30 PM
Quick Reply: Changing ignition key cylinder on F-6
