ignition switch key cylinder
Old Feb 8, 2005 | 12:04 PM
krautwolf's Avatar
krautwolf
Time to replace the 45 year old ignition switch. How do I remove the key cylinder?
Old Feb 8, 2005 | 12:22 PM
IBlock6's Avatar
IBlock6
There should be a small pin on the rear top of the housing. With the key in the switch it will depress. Without the key in it won't. I had to replace mine when I lost the only key I had. With out the key, I had to drill off the pin. It was not the cleanest method, but it worked. Hope this helps
Conor
Old Feb 8, 2005 | 06:33 PM
AXracer's Avatar
AXracer
It might be easier to take it to your local locksmith, he can replace the cylinder and key it to match the original key and/or the door key. It shouldn't be more than a few bucks.
