spindle arm lock nut
If it's a lock nut, it's supposed to be hard to install (hence the 'lock' moniker). If not, it would benefit from running a thread chaser (not a tap) through it. New hardware these days is notorious for having sloppy threads and being hard to put together.
Probably what your are dealing with is the heavy handed mechanic that put it in originally hit it so hard he compressed the threaded portion which expanded it.
Can you get a thread chasing die on it? That would restore the proper diameter.
Leave the broken drill bit in there but grind off any part of the bit that extends into the threads. When you assemble it, use an self locking nut and red locktite.
If you use a chaser be sure to go slowly and use plenty of cutting oil. For each full turn of the chaser back off 1/2 a turn to break off the chip that forms on the leading edge of the chaser. Then advance another full turn. This is a procedure that you cannot hurry. Take your time and your threads will be as good as new.
Texas Outlaw
12-22-2010 01:21 PM
jim henderson
03-23-2010 07:44 PM
