I'm in the process of installin a lift.. i dorked up the radius arm nut. Anyone know what size it is so i can grab a new one?
I don't know but if it was me I would get the cheapest bushing kit I could find and use the nut out of that. That way you'd be sure to have the right metal besides the sizing.
yeah it was! I am now having issues though. The new radius arm bracket is a lot thicker than the stock stamped one. there isn't enough tread on the radius arm (stock) to fit the back bushin and nut on.. And ideas?
hrmm thats weird what brand lift is it... because... i put a procomp lift on my truck 6" ... and the brackets they gave me were half a inch thick and they still worked.. take just the washer and nut and tighten it on and see if that helps .. bring some more threads out
If you have new bushings as well, you may need to pull the TTB axle back into the bracket a little to get it started. Is the tuck on the ground or in the air?
