about to blow up my truck.... need a hand
ok, I have a 2006 f250 xlt, it seems like everytime I want to dosomething with my truck, it wants to fight back. I bought a center console, i wanted to replace the flipup seat. I drilled and screwed the console down. its dead center, i looked at my friends truck put it almost exact where it is. ok cool its in the truck, looks great.... now my truck wont unlock. It will lock remotely, and from the inside. Remotely it wont unlock or inside. SO now im at the point, did I just drill a wire, wouldnt I of noticed it? Is there a fuse I should look at?
You didn't need to drill anything to mount the center console. It sandwiches under the seat brackets.
Anyway, this might be unrelated to the console. Your truck will not lock with the FOB if a key is in the ignition. This is normal behavior to keep you from locking your keys in the truck. So it is possible that the truck thinks your key is in the ignition, even though it isn't. Which would mean the key sensor is somehow acting up. Mine has done that too, and a shot of WD40 in the key hole, and working the key in/out a bit fixed it.
Just noticed your problem is with unlocking, not locking. Oh well, maybe it will help someone some day.
Sequoyah
1997-2006 Expedition & Navigator
05-20-2008 08:16 AM
