Another overhead console post..
Old Aug 16, 2017 | 09:42 PM
ronmo's Avatar
ronmo
Question Another overhead console post..
2003 F250 Lariat console,
Because of everything I have read I was sure the problem was a bad circuit board, I never even looked for a fuse.
I had Dave Ruberg fix mine for $22 (Dave is super nice on the phone and fast service. It was back in the mail within 2 hours of delivery to him)
I got it back yesterday and put it back in last night and it is still dark....
SO NOW after looking through the manual, there is no fuse location listed for the overhead console.
I have had the truck for 6 months and everything electric works, so DOES the console have a fuse that I should have checked before and need to find?
I called Dave, he said to check, there should be 6 plugs (wires) on the top row and 4 on the bottom row.
My truck's plug has only has 5 (wires) for the top row and 4 on the bottom. (The plug and everything else sure looks to be factory..)
The circuit board has 6 pins on the top row and 4 on the bottom row, (two on each side with a 4 pin gap in the center).
Anyone know of a fuse OR have theirs open to have a look and see If my trucks plug is missing a wire... (HOW could that be?)
Thank all
Ron
Old Feb 19, 2018 | 02:04 PM
ronmo's Avatar
ronmo
Bump.
Also my visor vanity lights, and glove box light has not power.
I pulled every fuse under the dash and all were good. Further confused when I looked at a chart and the list of what is on the same circuit as the glove box light..
Old Feb 19, 2018 | 02:45 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
See attached diagrams. This is for 2002 but pretty sure it's the same as 2003. Looks like the console fuse is 27. This shows the 12v power to be blue/pink but I recall it black/pink. Top left pin when looking at the connector, see if yours is disconnected and prairie dogged back into the harness.
The interior lights diagram will show the glovebox fuse info.
File Type: pdf
File Type: pdf
Old Feb 19, 2018 | 07:59 PM
ronmo's Avatar
ronmo
thank you
I will have another look. The schematic should really help.
Ron
YellowSled
Jan 23, 2009 10:16 PM
YellowSled
Jan 23, 2009 06:19 PM
dieselstroke
Electrical Systems/Wiring
Mar 11, 2008 09:09 PM
fuddy
Aug 21, 2007 11:08 PM
