I have a 2006 Ford F150 FX4 crew cab. The vehicle is equipped with two 12V data socets. One located in the rear of the center console and the other on the dash (passenger side). The one on the rear of the center console works fine. The one on the dasj on the passenger side does not work. I believe I blew the fuse but when I checked the owners manual to see what fuse it was but I couldn't find it. I pulled all of thefuses out of the fuse box one at a time to see which one was burned out and they were all fine. Would anyone be able to tell me what fuse thus is that controls this 12V data outlet? Could it be a relay that controls it?
You said, ".......I believe I blew the fuse......". What were you doing? If you find the fuse is OK, you may have fried something in the socket itself.
