P1335 & P0404 Codes
Old 05-08-2012, 05:46 AM
Racin07jason's Avatar
Racin07jason
Racin07jason is offline
P1335 & P0404 Codes
2004 6.0L Excursion 82K. Over the weekend the check engine light came on. I pulled a P1335 Code (Position sensor min stop performance) code with SGII, so i cleaned egr valve. It was sooted but not wet or gummy. Intake looked a little sooted and was dry. I cleared the P1335 Then it threw a P0404 (Exhaust Gas Recirculation Egr open code). Truck runs great. My question is does the truck need to cycle a few times for the check engine to go off?
Thanks Jason
Old 05-08-2012, 05:58 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
You probably need to replace the EGR valve for the light to go off since it's bad.
Old 05-08-2012, 06:26 AM
Racin07jason
Ok. I thought maybe i could get away with cleaning the valve. I have an extended warranty so ill take advantage of that.
Thanks
Kallie
02-20-2007 07:03 PM
fazang
Bronco II
04-18-2005 09:14 AM
zippy564
05-04-2004 08:47 AM
Gunner Thomas
1999 to 2016 Super Duty
02-24-2004 09:56 AM
bufordt
12-10-2001 11:32 PM
Quick Reply: P1335 & P0404 Codes
