periodic small surges while driving & accelerating
Old Feb 20, 2007 | 12:18 PM
Kallie's Avatar
Kallie
Mechanic told me I needed an EGR valve and it was running rough mostly at idle. So I replaced it. It still ran rough but the idle was rougher. I had code 33 so we replaced the EGR sensor. Now it has periodically at least 2 times daily small multiple surges in a row almost not detectable . Now I have code 334. fire No what do I do?
Thank you,
Kallie
Old Feb 20, 2007 | 12:51 PM
andym's Avatar
andym
You can't get both 2-digit and 3-digit codes out of the same truck. They use one or the other, and your truck should use the 3-digit codes.
You could have gotten a bad EGR valve. Sometimes they leak past the pintle, even brand new. What brand of EGR valve did you get?
Old Feb 20, 2007 | 05:02 PM
Kallie's Avatar
Kallie
They are napa auto parts brand. The code 33 is what the mechanic said and I ran my codes this morning as I am tired of it running rough at idle. So I know that now it is code 334. So is there a way to test the EGR valve? Or could the EGR sensor be what is bad.
Thanks,
Kalllie
Old Feb 20, 2007 | 05:39 PM
DaMole's Avatar
DaMole
Mine did the same thing and it turned out to be the map sensor going bad but I did get a code for it so im not sure about yours. Could be something to check though when checking the EGR.
Old Feb 20, 2007 | 05:48 PM
BigJim191's Avatar
BigJim191
i had the same problem with my 94 F150 and i changed the coil first before the EGR and the rough idle and hesitation stopped...
Just a thought.
Jim
Old Feb 20, 2007 | 07:03 PM
Kallie's Avatar
Kallie
I will check it out
Thank you,
Kallie
fordboy97
Nov 12, 2015 01:28 PM
Flatbed
Feb 2, 2015 05:07 PM
devbravo
Jul 26, 2014 11:52 AM
wwblue05
Feb 12, 2014 05:28 PM
Kallie
Jan 3, 2004 01:45 AM
