Ranger owner, got a 351 for free need help!
Hey guys i have a ford ranger and have ben on here a little with it but now i got a 351 from my school and all i have are the numbers and am wondering what it is
heres the numbers on the block
D9ae 6015 ED 16
its out of a mid 80's ford school bus
any help please?
D9ae 6015 ED 16
any help please?
on
I see you have an 88 Ranger. I am thinking this is a full size truck and not a little Ranger? The numbers are casting and foundry markings I think and won't tell us much.
Is this 80 351 a W? An M or a C? I would guess a 351W. The 80 will not be a roller block and I don't think the 88 is either. They are flat tappet engines. Someone will chime in and tell us for sure.
I am not sure just what you want to know as you have giving very little information.
Do you want to put the bus engine in your truck? Does it run well? Gonna hop it up some first?
Also we like pic's. It's kind of a pain to post them and they will need re-sized unless you use like photo bucked or some similar.
This is how I do it and use and online re-sizer.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
1. Login to FTE.
5. Click Upload.
on
'88 Ranger is the little truck so this is a non standard swap, the Ranger Station has all the dirt on 302/351 installs so check it out.
D9AE is a 79 block assuming that is the block casting number, you'll have to supply the same from the heads as well and you'll find the numbers on the head gasket side on the bottom of one of the central intake ports so the intake has to be off at the very least to see them with a mirror. The heads should be of similar vintage and if they are this is a low compression smog motor, a swap to late model(E7TE or GT40 heads) would be beneficial, and then upgrade the cam to get all the potential that's just dying to get out and break little Ranger parts. And that brings up the next thing, you'll need an 8.8 rear diff and a trans from a fullsize truck at some point, the stock Ranger running gear will work for a short time if you're nice to it but you can expect to break things if it's wheeled or hammered on the street.
No the 351 is not intended to go in my Ford ranger. sorry for that mix up
i only said i had a ford ranger which is how i know about this fourm
the info i gave you is all i know,
i DO NOT KNOW IF ITS A W or C thats why i posted this,
so any help where else to look for numbers to give you guys more info?
on
Okay duvaltom. Lets start all over. We can do that here with no problem. It's all about us being able to fully understand what you need. That's why we are here is to learn and help. So you have a flat tappet 351W. This we now know for sure. Next is what do you want to do with it? How can we help? Please ask your question again and spell it out fully like you was teaching the first grade about the birds and bees or something. This I am told is one of the biggest (if not the biggest) forum on the net for this kind of thing. I assure you there is nothing you can ask about a Ford truck that someone here will not be able to help with.
Izzie1701
01-30-2014 09:59 PM
jbaysinger
15
08-02-2012 12:20 PM
mharring
08-01-2012 04:34 PM
