You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I bought a 390 flywheel and clutch set and put it behind my 460. Having a problem get the trans to mate up to the engine. I used the bigger 390 pilot bearing. I had bought a 460 pilot bearing but it was nowhere close to fitting.
Ok, so I've searched for this, and only found that a 302 pilot will work? But is this for T5, or older T18 or 19? I have the right T18/19 400m bellhousing, just need the pilot. The trans.is now bolted to 390FE, and I was planning on using the clutch and flywheel from 390.
The 460 is out of 77 econoline van, so it should be internally balanced. 390 and 4spd, are from late 70's F100 or F150.
I know the best way is to measure trans input shaft outer diam./ engine crank inside diam. And go from there. I was hoping someone has done this and knows, to save me time. Thanks in advance NP435 Bronco
i bought a non roller bearing pilot bearing and had a machine shop turn it down to fit deeper into the 460 crank, this allows for the connection of the engine and transmission to fit without the need of any shim plates.
