Adding turn signal mirrors?
He has no pictures of them that worried me a bit.
EDIT: he has a picture now, BUT is only driver side now and it is the wrong mirror for my truck (also I do not think it is heated like first ad stated
Ford Driver Side Mirror
can anybody assist?, just bought 2003 drive & passenger mirrors with everything including turn signal & clearance light, converting my old non turn signal ones to the newer version. i have everything connected but the turn signal and clearance light you know if the turn and clearance wires run on each side down behind the kick panel cover and/or under the rocker covers on the 2000 excursion, if so what the color coding might be.
Need Related Mirror Wiring Info Please
2012 F-150 XLT. Did not buy the convenience package so my mirrors have inserts where the turn signal lens would go. Living in Arkansas we really don't need heated mirrors. I want to install the lens and Ford shows them as parts. I popped the inserts but don't see any wiring. None of the lens photos I can find show any wiring. I also asked the dealer if the truck came prewired and they did not know. Seems to me Ford would prewire all trucks on the line because many come with the extra package. What I would like to know is
1) Are the trucks prewired? If not, how far away is the nearest turn signal wire. I figure the other wire is ground.
2) Any source for the lens other than from Ford where they are pricey.
3) Any other suggestions about wiring them, etc.
4) Thanks
4) Thanks
