Hey all - Does anybody know if the turn signal wiring is in the mirrors already. Mine are electric mirrors w/ no turn sigs.Just wanting to add the turn signal marker lamps. Any body done this on an 02 Lariet? Thanks,
I just put these on my truck Monday. To answer your question, no the wiring is not already there. You will have to go with the newer mirrors. Also you will have to run wire from the door into the cab to get the lights and the mirror heat to work.
just hook them up to your turn signals, instead of diving into the cab for sources. run them down the fender to you turn signals and youre done
