1990 f150 leveling kit
Old 05-07-2012, 04:45 PM
zeeck2's Avatar
zeeck2
zeeck2 is offline
There's 31's on there now along with 15x8 wheels goin to change both
  #32
Old 05-07-2012, 07:03 PM
minnesotafisherman's Avatar
minnesotafisherman
minnesotafisherman is offline
Originally Posted by TexasGuy001
On a 2wd with a leveling kit or F250 springs 33s wont fit well if at all.
Originally Posted by 95f2504x4
Like Texasguy said idk if the 33s will fit in a 2wd even with those springs.
F250 (Moog CC844) coil springs, 33x12.5x15's, 3" body lift, MY Truck:
2" leveling kit, 33x12.5x15's: (NOT my truck)
BOTH are 2WD's
  #33
Old 05-07-2012, 07:39 PM
zeeck2's Avatar
zeeck2
zeeck2 is offline
I think ima run a 32x11.50
  #34
Old 05-08-2012, 01:12 PM
Fungus232's Avatar
Fungus232
Fungus232 is offline
Here's my $.02 since I JUST went through this last week...
MOOG CC844 springs up front which brought it up exactly 1.5" ('95 F-150 in my sig).
I saved about $50 by getting the castor/ camber adj bushings myself at Napa vice buying them from the alignment shop. The shop gave me the part# they were going to use, Napa cross referenced it & gave me their brand of bushings (about $30 each w/ military discount).
So to recap, I installed the springs myself and purchased the castor/ camber bushings. Alignment cost me $196 out the door. This was to install the caster/ camber bushings & the subsequent alignment.
Oh yeah, TIRES! I was running 32x 11.5x 15s until one went bad last week (yes, 1 day after the alignment was done!). That size seems to be hard to come by out here and getting limited from the mfgs. I decided to drop down to 31x 10.5x 15s and am very happy with them! Super quiet. Surprisingly so as aggressive as they are. Kelley Safari TSR radials.
  #35
Old 05-08-2012, 01:40 PM
zeeck2's Avatar
zeeck2
zeeck2 is offline
@Fungus before and after pics??
  #36
Old 05-08-2012, 02:00 PM
Fungus232's Avatar
Fungus232
Before/ After shots of the MOOG CC844s. This is with the 32x 11.5x 15s.
  #37
Old 05-08-2012, 02:35 PM
andym's Avatar
andym
andym is offline
Looks a lot better with the lift springs IMO.
  #38
Old 05-08-2012, 02:41 PM
zeeck2's Avatar
zeeck2
zeeck2 is offline
Kool, looks clean and can notice a difference, handling- better or worse??
  #39
Old 05-08-2012, 02:52 PM
Fungus232's Avatar
Fungus232
I like the handling. More firm for sure but not harsh. Corners alot better. They brought the front end up within 1/4" of level with the back; front end is still 1/4" lower but perfect IMO.
  #40
Old 05-08-2012, 04:17 PM
minnesotafisherman
Yeah after I installed mine it completely eliminated the body roll around turns.
2WD with F250 coil springs won't sit as level as his, though. 4x4 sits a bit higher in the front. I still have a bit of lean to my truck, been thinking about tearing them out, putting some stock height coil springs, and 2" coil spacers in.
I can post some before/after of mine when I get a chance.
  #41
Old 05-08-2012, 04:33 PM
zeeck2's Avatar
zeeck2
zeeck2 is offline
Yeah I was thinking coil spacers but since I've gotten so much info the 250 springs I'm goin with them
  #42
zeeck2's Avatar
zeeck2
zeeck2 is offline
Still need an alignment with the coil spacers??
  #43
Old 05-08-2012, 06:49 PM
Fungus232's Avatar
Fungus232
Yes. When lifting the front end you change the geometry of the steering linkage so an alignment would be highly suggested to keep from wearing your tires and linkage out.
Kaizer88
04-16-2012 07:04 PM
indebt
16
03-10-2009 05:39 PM
LARIAT 85
06-18-2008 06:46 PM
dehamma
01-09-2004 02:16 PM
Sherlock101
09-10-2003 10:09 PM
Quick Reply: 1990 f150 leveling kit
