1990 f150 leveling kit
I'm looking for a levelling kit to bring the front up and also fit a bigger tire, any suggestions, I was thinking coil spacers, n are they easy to install??
One of the best solutions would be to run the moog cc844 front coil springs. They are 250 coil springs and will give you about an inch and a half lift in the front.
Kool where could I find those, n are they easy to install
http://m.oreillyauto.com/mt/www.orei...3360&ppt=C0361
That should do it and if that doesn't come up right(on my iPhone) just go to oriellys have them look up the moog cc844 and if they ask what's it's for just tell them 1990 ford f250 2 wheel drive front coil springs. Just make sure you get the cc844. There are other options like the cc822 and cc824 but everyone here runs the cc844 and they like them. They are not to hard to install just as long as you know your way around a car if not just have a shop install them for you. The springs from oriellys run about 100 bucks |
Kool sounds great, thanks a lot brother
Not a problem that's what these forums are for. And everyone is so helpful.
Unfortunately, he left out a couple of pretty significant details. If you put these springs on, your truck will ride a lot stiffer. Your front tires will also look like this: \---/
Not good. You will need to install a camber bushing to fix the alignment. You will never get it lined up right without the correct camber bushing. |
See always someone to help cause I knew I forgot something. Thanks Andy.
So the part # for the bushing is??
Originally Posted by zeeck2
(Post 11792310)
All good bro, thanks for everything
In my opinion springs are the right way to do it. I have Superlift 117 coils on mine. It sits just under level now. It will need an alignment.
The allignment shop will have the bushings that are needed to properly allignment it. Just make sure you soak the top balljoints nuts good with your favorite penetrating fluid a couple times for the day or two before.
@midnite 1987, thanks I thought I was. Gna run around n have to find the bushings
Have fun getting that front end aligned afterwards, my local shop aligned the truck in my sig after installing the 844's and it cost me $380.
