Check engine light
10-03-2012, 07:18 AM
Check engine light
So drove into work this morning and my check engine light is on everything sounds fine no running issues still feels strong. My short drives are probably killing this motor but I have to hang on to it for a while longer. Any ideas where to start looking?
10-03-2012, 08:11 AM
Get the code read. probably an emissions issue of some kind. It probably can be read at autozone/o'reilys napa ect. since it is not a wrench light.
10-03-2012, 08:16 AM
Quote:
Originally Posted by
senix
OK so should I go there instead of my dealer? I made an appointment for today but I can cancel it thought
10-03-2012, 10:01 AM
If you are under warranty then certainly the dealer as the best choice. If you just want to know before deciding then it is up to you.
10-03-2012, 10:33 AM
Yeah im 08 with 70,000 so I guess im still under the engine warranty well see what they tell me thanks for the advise
10-03-2012, 02:24 PM
OK well its an exhaust sensor between dpf and the cat around $370 to fix no warranty
10-03-2012, 02:31 PM
Yeah..that is a non warranty item. Check your emissions warranty. I still think it is not covered there either.
10-03-2012, 06:22 PM
got the part number for the sensor? I have a few new ones kicking around.....I could probably save you a few bucks...
10-03-2012, 06:37 PM
Thanks but I had it replaced already had to tow a skidsteer tommorow so needed it up and running
Jeff heine
07-29-2018 09:04 PM
urboman
6.7L Power Stroke Diesel
02-15-2011 09:01 PM
90F250351
1999 to 2016 Super Duty
09-08-2009 02:07 PM
blockmanjohn
06-11-2006 07:55 PM
papa737
03-06-2006 11:40 AM
