6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Check engine light
Old Oct 3, 2012 | 07:18 AM
bigjr2's Avatar
bigjr2
Check engine light
So drove into work this morning and my check engine light is on everything sounds fine no running issues still feels strong. My short drives are probably killing this motor but I have to hang on to it for a while longer. Any ideas where to start looking?
Old Oct 3, 2012 | 08:11 AM
senix's Avatar
senix
Get the code read. probably an emissions issue of some kind. It probably can be read at autozone/o'reilys napa ect. since it is not a wrench light.
Old Oct 3, 2012 | 08:16 AM
bigjr2's Avatar
bigjr2
OK so should I go there instead of my dealer? I made an appointment for today but I can cancel it thought
Old Oct 3, 2012 | 10:01 AM
senix's Avatar
senix
If you are under warranty then certainly the dealer as the best choice. If you just want to know before deciding then it is up to you.
Old Oct 3, 2012 | 10:33 AM
bigjr2's Avatar
bigjr2
Yeah im 08 with 70,000 so I guess im still under the engine warranty well see what they tell me thanks for the advise
Old Oct 3, 2012 | 02:24 PM
bigjr2's Avatar
bigjr2
OK well its an exhaust sensor between dpf and the cat around $370 to fix no warranty
Old Oct 3, 2012 | 02:31 PM
senix's Avatar
senix
Yeah..that is a non warranty item. Check your emissions warranty. I still think it is not covered there either.
Old Oct 3, 2012 | 06:22 PM
slowmans's Avatar
slowmans
got the part number for the sensor? I have a few new ones kicking around.....I could probably save you a few bucks...
Old Oct 3, 2012 | 06:37 PM
bigjr2's Avatar
bigjr2
Thanks but I had it replaced already had to tow a skidsteer tommorow so needed it up and running
Jeff heine
Jul 29, 2018 09:04 PM
urboman
6.7L Power Stroke Diesel
Feb 15, 2011 09:01 PM
90F250351
Sep 8, 2009 02:07 PM
blockmanjohn
Jun 11, 2006 07:55 PM
papa737
Mar 6, 2006 11:40 AM
