cab lights
Old 04-17-2012, 01:15 PM
bieryj's Avatar
bieryj
bieryj is offline
cab lights
I have a 1993 Ford F150 without cab lights. I want to put some on but I wasnt sure how hard that is to do and if anyone had some pointers.
Old 04-18-2012, 04:29 PM
TrdLtly's Avatar
TrdLtly
TrdLtly is offline
TreadLightly
While this is the right forum to post in, you will probably have better luck searching over in the 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums. Make sure you search that forum first, so that you don't post a question that has been discussed at length already. Good Luck!
Old 04-21-2012, 10:13 AM
ReAX's Avatar
ReAX
ReAX is offline
They aren't that hard. Place the lights how you want them (spacing and square to the windshield) then mark the holes to pilot. remove the visors and drop the head liner, then pilot drill the holes. If you want the lights to work, you'll need drill a hole for the lighting wires.
Set your screws in the lamps, slide the gasket on the screws, put a dab of silicone in the holes in the roof and gently/evenly screw the lamps down. Connect the wires, run them down the A-Pillar to the head light switch.
nagetech
1999 to 2016 Super Duty
24
11-13-2020 04:04 PM
Dan_T
06-18-2012 12:39 PM
4starcstms
35
01-05-2010 08:23 PM
wolfe1104
02-16-2007 07:42 PM
jjk74
06-21-2004 07:39 AM
Quick Reply: cab lights
