Sponsored by: Real Truck
Adding Cab Lights
Old Jun 21, 2008 | 05:54 PM
4starcstms's Avatar
4starcstms
Adding Cab Lights
I want to add cab lights to my 04. Nothing fancy, the stock ones are what Im gonna install, how hard is this going to be??
I rember on the 92-96's there was a Inner panel and the roof Skin, are the SD's this way too?
Thanks!
Old Jun 21, 2008 | 06:23 PM
ReAX's Avatar
ReAX
I don't remember the ribs above the head liner, but a sharp drill bit will cut through it either way. There are some pilot point bits that are rather nice.
The roof is curved close to windshield, so your going to need to take your time in placing the lights. Get some wide masking tape and tape up the roof, then position your lights and draw their out line with sharpie. Slap your template in the out line and drill the holes.
Old Jun 21, 2008 | 06:33 PM
4starcstms's Avatar
4starcstms
Thanks! Be a good weekend project
Old Jun 21, 2008 | 08:38 PM
spinella's Avatar
spinella
do a search.i remember seeing a very detailed "how to" on installing cab lights.it had part #'s and all measurements needed.good luck.
Old Jun 21, 2008 | 10:04 PM
4starcstms's Avatar
4starcstms
I checked the Tech Folder thinking it might have been made a sticky.. no luck thou... I'll do a search-thanks!
Old Jun 21, 2008 | 11:42 PM
RACERX7775's Avatar
RACERX7775
definately search. there are a couple threads on here that are very exact with tons of pics and measurements.
Old Jun 22, 2008 | 12:10 AM
4starcstms's Avatar
4starcstms
Just for anybody else who's looking... Good Info found here: Motoman's Madness
Old Jun 22, 2008 | 09:01 AM
DAFBFD58's Avatar
DAFBFD58
Yes that is the site i was going to tell you. Now I suggest a step drill bit. I makes the whole process so much easier.
Old Jun 22, 2008 | 11:56 AM
mind's Avatar
mind
Here is my write up when I did mine if you like more pictures. I followed motoman's also. Writeup Here.
Old Jun 22, 2008 | 12:14 PM
RACERX7775's Avatar
RACERX7775
ha, i knew i saw it somewhere. i have it in my favorites. i have all the stuff but i dont have the b***s to drill in my roof yet. plus i have to take my headliner out. and thats like 11 feet long. thanks for reminding me about it. oh, both of you have great writeups.
Old Jun 22, 2008 | 12:31 PM
supeRobertduty's Avatar
supeRobertduty
Are you sure you want to drill holes in your roof ?
Old Jun 22, 2008 | 07:45 PM
4starcstms's Avatar
4starcstms
No different from the factory doing it. Wouldnt be the first time, I drilled and mounted lights on my 75 ...
Unibits are the ONLY way to go!!
Old Jun 22, 2008 | 09:17 PM
supeRobertduty
Smile
Well yes and No , A factory cab light truck has the holes pre-made , Then the cab is dipped for rust, primed and painted.
I am sure you will have no problems but just the thought of drilling all those holes just for the look's of it would scare me.
Old Jun 22, 2008 | 11:29 PM
WildWildWest's Avatar
WildWildWest
Many members including myself have done it on our trucks and it is not that difficult to do. You also do not have to remove the whole headliner, just drop it a bit in the front. Many dealers install these after the trucks hit the lot and they do it the same way the instructions are laid out - the trucks already have the plugs for the wiring harness to plug right in on the passenger side kick panel. (Excursions don't have it prewired I don't think). Easy job, just measure twice and drill once. I would rate this about a 2 out of 5 on a difficulty scale.
Old Jun 22, 2008 | 11:30 PM
RACERX7775's Avatar
RACERX7775
well, not pre-made. more like punched out. there are tools out there that actually punch the holes instead of drilling. it doesn't really matter. greenlee????i also use touchup paint on the bare metal surface after i drill through things. sort of preventative maintenence.
