EBP Tube
Old 04-08-2012, 06:37 PM
waterboy_fishing's Avatar
waterboy_fishing
waterboy_fishing is offline
EBP Tube
Is there an EBP tube and sensor to clean on the 6.0?
Old 04-08-2012, 07:36 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Yup, not a great pic. It's input is ignored on the 03 and early 04 trucks if they have been reflashed.
Page 9: Component Locations
Old 04-08-2012, 07:37 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
your 03 dont use EBP
its there the sensor for EBP just not in use
whats the matter with your truck
Old 04-09-2012, 06:49 AM
waterboy_fishing
I'm just looking at things that may need attention. I just recently cleaned and unplugged my EGR. No check engine either. Its got 103,000 on it and I have only kept the oil changed every 5,000, tranny flushed every 50,000, air filter just changed, and fuel filters last fall. Getting some poor mileage so I'm researching things to check or clean that maybe an issue. The FICM is next as soon as I get the time. Any other suggestions would be appreciated.
Old 04-09-2012, 07:11 AM
bismic's Avatar
bismic
bismic is online now
Received 2,491 Likes on 1,728 Posts
If he has NEVER been reflashed, then his PCM could (probably) still uses it. If he took it into Ford after May of 2006 or so, then he probably doesn't use it (Ford reflashes even if you don't ask for it). The inferred EBP flas came out in mid 2006.
As far as mileage goes - check dragging brake calipers, stuck AC clutches, tire pressures, etc.
Old 04-10-2012, 06:38 AM
waterboy_fishing
I'm sure it has been reflashed. It's been in the shop for fuel injectors, transmission flush, and hub replacements before so I'm sure they did it. The Transmission was just done a few months ago. No break drag, tire pressure are normal. I read that when they relashed them that may be causing some of the loss in mileage.
Old 04-25-2012, 04:10 PM
Orangeoutlaw's Avatar
Orangeoutlaw
Orangeoutlaw is offline
Is there a way to find out if mine is in use? 2004 f250 2/04 build date. Have a P0299 code and wanted to try everything before pulling turbo as boost is good and heard ebp tube cleaning can help. Just cleaned EGR valve. Thanks
Old 04-25-2012, 08:16 PM
kidoo's Avatar
kidoo
kidoo is offline
NOw, my truck is a 2006, does it use EBP? I just kleen the dam thing and it was not easy to unscrew.
Old 04-25-2012, 08:25 PM
6.0techwannabe's Avatar
6.0techwannabe
6.0techwannabe is offline
Driver side manifold,remove air filter. Cant miss it
Old 04-25-2012, 08:31 PM
6.0techwannabe
Loss of power might be attributed to a few things. Bismic knows his ****,id check and recheck what bismic is sayn. You need a lab scope to see if things are worn or wearing,a scanner to read values. If it were my truck i would pull the turbo,knock the hot side off and clean the bugger out.
Old 04-25-2012, 08:51 PM
bismic's Avatar
bismic
If a scangaugeII will get an EBP reading, then your flash is probably using it (and vice versa) - at least that is how I understand it.
Old 04-25-2012, 08:59 PM
kidoo's Avatar
kidoo
kidoo is offline
This is what I was thinking, i read EBP with scangauge, since the input is from the sensor, then .... I have read here 6.0 PowerStroke bulletins
That 03 and 04 had a recall to cancel the EBP reading by the computor. But it looks like it was just to clear a problem with these years?
Since they left the EBP on the 2006 engines, I would imagine it is use somehow. Plus there is a few test to perform with the EBP.
Old 04-25-2012, 10:27 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Why did Ford reprogram the ECU to ignore the EBP sensor on the 03 trucks?
It is used on the later trucks.
Old 04-25-2012, 10:33 PM
bismic's Avatar
bismic
http://www.flatratetech.com/downloads/diesel_8.pdf
2003/04 Computer Programming Recall 06E17:
Truck built before 9-29-03 are being recalled to have the computer reprogrammed. The reason for this recall is to correct fuel injection timing during cold operation, EGR valve control, lack of power, check engine light illumination (P02263 or P0299), hard starting and rough running concerns related to Exhaust BackPressure sensor corrosion. Other symptoms not listed in this recall, but which could occur, would be excessive smoke, turbo control and surging at idle or cruise. The new update eliminates the EBP sensor input to the computer. The exhaust backpressure will now be inferred/calculated using other sensor signals. Trucks should be reprogrammed using versions 41.8 or 42.1 or higher.
After this reprogramming, the truck should be test driven, the computer checked for a codes and the codes cleared (even if none are present), the key cycled on for five seconds, then turned off twice, then the engine started and allowed to idle for 5 minutes at operating temperature to allow the computer to relearn the EGR valve closed position value. This is to prevent erronious codes or driveability sysmptoms related to the EGR valve an turbo performance. Broadcast Messages 5452, 5529.
You should notice an increase in turbo cycling closed/whistling at idle and at stops. This is normal, and is to help keep the variable vanes from sticking.
04badford
09-17-2012 08:11 PM
K80
04-03-2011 07:15 AM
Deluxe06
37
12-18-2010 12:58 PM
BENG0924
05-18-2008 08:12 PM
getnbz
1999 to 2016 Super Duty
11-01-2007 10:24 AM
Quick Reply: EBP Tube
