OK while the truck was surging ,bucking,and acting a fool, I had no petal no acceleration,I had slowed down to make a turn and what the hell nothing, the truck Idialed about 3/4 mile down the road , bam petal cam back, lucky I would say I was back in the drive way. so earlyer in the day ran rough pulled a dump trailer to the job, drove most of the day say 100+ miles no problems no surge no buck fart spit sing or cussin the truck ran as if nothing was wrong untill then.
03/04 350 6.0 turbo, some body in fte has to have the same Issuies so Please help this frustrated ford OWNER.P.s soon will be getting scan gauge II no problem on cld start or ht start, did water separator a little h2o not much I run howes diesal treatment every tank reg maint on oil changes, ? maff, vct , tps is new ficm is new 6 months, I dont know the out put , batt new three months this has been a 1 yr problem since heads were done, time for fuel filters sunday.Thanks
thanks for your reply this truck has been the bur in the seat. Ebt Tube by the CoolentThermo stat its a 04 early 03/04 , thermo stat right of egr big 90 to the right drivers side , right, no hard start thermo seems good does the tube get pluged and why, I will pull and check to make shur . Thank you . After truck is warm why no Acelleration for that first time just stoped no petal 3/4 mi with my ft pumping to get it on to more , I will look at the tech line to see where its at thanks.
the only codes were from the egr and I did unhook for two day, scan checked with a otc3108 scanner please look at the other link I'm still in a learning faze with fte linking
