Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 04-02-2012, 08:12 PM
jl4407's Avatar
jl4407 jl4407 is offline
Garage is empty, add now
jl4407 is starting off with a positive reputation.
new oil cooler and still high eot's
OK, I did a oil cooler and egr delete about 2 months ago and all is good until my trip this weekend. I noticed on the highway at 70 MPH my eots were claiming to high. I hit 218 at one point my ects were around 190 -200. I am running zerex g05 I just don't get why my eots are high. As soon as I slow down off the highway they will come down to within 4-6 degrees. Any thoughts??
__________________
04 psd 6.0 fx4, 4 door long bed, straight pipe, egr delete, new oil cooler, edge insight
  #2 (permalink)
Old 04-02-2012, 08:24 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
2003 Ford F-350
BLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud of
Yep lots of thoughts
1 thing though How were the temps after the new oil cooler was installed???
Guess Im getting at could the oil cooler be plugged again this depends on this^^^^^
__________________
Benny
2003 6.0, 4X4 srw, short box, born on 3/28/03 Moog ball joints,DC POWER 190A ALT Duralast Goldtop batterys 10/7/2012,RECON LED SMOKE MIRROR LENS,4 inch turbo back magnaflo exhaust,no kitty, 6 in. lift, BFG 315/75r16, python remote start alarm,pioneer system2 12''subs 1600watt amps ,scangaugeII,coolant filter, blue fuel pres spring, Fresh oil cooler 6/1/11 Final Charge Cat EC-1 rated Silicate Free ELC coolant, Sinister Full egr deleate, ROTELLA T-6 5w-40syn,updatedHPO screen,updated oil filter stand pipe
  #3 (permalink)
Old 04-02-2012, 08:30 PM
jl4407's Avatar
Temps seemed to be good, I think this was the first time I had it on a long trip so I'm not sure. I did a good flush with vc9 before new oil cooler!! You think it could be cloged again, is it true you can have a little higher oil temp with the egr delete?
__________________
  #4 (permalink)
Old 04-02-2012, 09:07 PM
jl4407's Avatar
I'm wondering if since the cooler is new I could try and flush whatever might be in there out. If not then I guess out it comes, I'm stumped, all the time it took to change it out and still same problem
__________________
  #5 (permalink)
Old 04-02-2012, 09:21 PM
BLADE35's Avatar
2003 Ford F-350
Quote:
Originally Posted by jl4407 View Post
Temps seemed to be good, I think this was the first time I had it on a long trip so I'm not sure.?
Well this makes it hard to say what exactly is Going on here
How Many Miles on the New Oil Cooler????
Folks have had good luck flushing new oil coolers that plug soon after the Install vs a Plugged oil cooler that has 80K on it and PACKED with S@!T
I did a good flush with vc9 before new oil cooler!! You think it could be cloged again,?
Its Possible and you wouldnt be the first on to have this happen
or the other Possiblities would be a Coolant flow Issue
Yes you can have a Bigger Spread since the EGR Cooler is removed and you dont have to worrey about a EGR Cooler melt down and the problems that come with it. The system is alittle More Forgiving without the EGR Cooler
But you still need to cool the Oil IMO
so you still Apply the ECT vs EOT Deltas the same to determine the Oil Cooler Health
__________________
Benny
  #6 (permalink)
Old 04-02-2012, 09:24 PM
BLADE35's Avatar
2003 Ford F-350
Do you have and run a coolant filter
__________________
Benny
  #7 (permalink)
Old 04-02-2012, 09:31 PM
jl4407's Avatar
Quote:
No I'm not running a filter, though I'm sure my wife ordered me one for my bday next week!!
The new oil cooler has maybe 1k on it, I have read its more possible to flush a new cooler vs a old one like you said, its just frustrating that it might be clooged AGAIN. Should I do a vc9 flush or just a water flush?
I would think I'm good on coolant flow due to the truck running at 190, right?
__________________
  #8 (permalink)
Old 04-02-2012, 09:52 PM
BLADE35's Avatar
2003 Ford F-350
No I'm not running a filter, though I'm sure my wife ordered me one for my bday next week!!?
Better Late than never
The new oil cooler has maybe 1k on it, I have read its more possible to flush a new cooler vs a old one like you said, its just frustrating that it might be clooged AGAIN. Should I do a vc9 flush or just a water flush? ?
At the minimum it needs flushed right at the Port the egr coooler hose goes to but forced threw the oil coooler.
Sound like you might have a bunch of garbage in the cooling system. did you pull the block drains and lower hose and heater lines and reverse flush each section of the coolant system. Even pull thermostat and run cleaner VC-9 threw it at High Idel or 1100-1200 rpms for an Hour parked ?????
I went to Great Lengths to flush mine before I installed new Oil Cooler and seemed to work 15K since and 4-6* spread HWY
Hard to say I know what your getting at with the ECT running at 190* But thats Not the whole storey
Its Harder for the WP to push coolant threw the small veins of the Oil Cooler vs Around cylinders/Heads
Throw a Bad WP or Cavitated front cover in the mix and could have a hard time pushing coolant threw Oil Cooler
IMO First thing to try is Flush right at the Oil Cooler to EGR Cooler Port see what happens stuff a hose in every Port/Hose connect and flush GOOOOD
__________________
Benny
  #9 (permalink)
Old 04-02-2012, 10:11 PM
jl4407's Avatar
I did all of that minus the block drains.
I'll go get some vc9 and do another flush, but first I'll pull that cover off and flush the cooler dirctley.
__________________
  #10 (permalink)
Old 04-02-2012, 10:23 PM
BLADE35's Avatar
2003 Ford F-350
Does your ECT & EOT read the SAME Temp after a 12 Hour Cold soak
theres been a few Bad Temp senders on here the last couple weeks to causing aerror in the temp readings
Just thought that I would throw thes 2 things out there
__________________
Benny
  #11 (permalink)
Old 04-02-2012, 10:26 PM
jl4407's Avatar
Yes they are the same at cold soak, I was thinking the same as you but they are both the same first thing in the A.M
__________________
  #12 (permalink)
Old 04-03-2012, 03:29 AM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
2005 Ford F-350
Snuggyworm has a great reputation on FTE.Snuggyworm has a great reputation on FTE.Snuggyworm has a great reputation on FTE.Snuggyworm has a great reputation on FTE.
snuggyworm snuggyworm Snuggyworm
did u install a new temp sensor after flushing?
did u clean ur ebp sensor? those sensors and stuff, i'd clean wat i can, and i'd replace those tat i'm supposed to. ur readings may be a little off, cos of tat.
jus my 2 cents.
__________________
Dom
2005 F-350 PSD 6.0 KING RANCH 4X4 DRW
Ravelco Plug, Updated HFCM Drain Plug, ScanGauge II, Blue Spring Upgrade, Sinister Diesel Coolant Filter Kit, Updated STC Fitting, Upgraded FICM (6/14/12), Complete EGR Delete kit (5/13/13), Shell Rotella ELC, Bilstein 5100 Racing Series Shock Absorbers & Steering Stabilizer, Bilstein Front Coil Springs, Magnefine P.S. Filter
Tags
1994, 60, 60l, adding, code, cooler, eot, external, flush, ford, high, oil, probe, taurus, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
