Styleside Mounting to Chassis
Old 05-10-2012, 10:56 PM
montego69's Avatar
montego69
montego69 is offline
Hi all,
I'm working on remounting the styleside box to the chassis in my '60 F100. According to my manual, it lists the usual 7/16-20 carriage and hex bolts, nuts, and washers. The middle mounts have the usual wood blocks that I remade based on the drawings I found elsewhere on this forum. Those sit right on the chassis. It's the front and rear mount that I'm questioning. Is there anything that goes between the chassis and the steel of the reinforcement channel that is part of the box floor? I took it apart 2 years ago and everything was slopped out or missing. I know the other box styles use some tire carcass according to the parts manual but this styleside doesn't appear to use anything. Should I just mount the box tight to the chassis and let 'er ride?
Can anyone help me out?
Thanks all,
Nick in WI
Old 05-10-2012, 11:07 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Nick my 59 had tire carcass. I would not go metal on metal.
Old 05-10-2012, 11:14 PM
montego69's Avatar
montego69
Tire Carcass
Thanks for the reply! Tire carcass even under the wood blocks?
Nick
Old 05-11-2012, 11:16 AM
theodore/teddy
Refyred
Mine had nothing between the wood and frame, but the mounting kits supply rubber pads for all bolt locations. You could easily improvise with material from the hardware store.
Old 05-12-2012, 07:23 AM
Walston's Avatar
Walston
Walston is offline
I put a thin layer (+/- 1/8") of rubber between all mounts on the bed.
KRBTFD
2004 - 2008 F150
05-03-2018 01:27 PM
onug
2015 - 2020 F150
01-08-2017 09:29 PM
5Rangers
08-18-2011 05:38 PM
jmm
01-08-2008 11:01 PM
donsboy
02-15-2004 10:58 AM
Quick Reply: Styleside Mounting to Chassis
