longbed
Old Jan 8, 2008 | 07:33 PM
jmm's Avatar
jmm
longbed
will a regular longbed work on a highboy frame? or do i need to find a specific highboy box. i was told a regular box would work but i would have to modify the mounting?
Old Jan 8, 2008 | 08:20 PM
ranger429's Avatar
ranger429
Frame is narrower on a highboy than the later 77.5 and up.
Old Jan 8, 2008 | 11:01 PM
plowpusher's Avatar
plowpusher
yes it will work but you have to shim it and drill new holes for the mounts because the risers are different hight and the frame is narrower what i've done is drill the holes first with a 1/4 drill from the bottom then go down from the top with a hole saw the same diameter as the outside dia of a a piece of 1/2 inside dia pipe put the pipe in and weld it to the box floor to make a solid mount for the box bolts other wise you are just bolting through the box floor to the bottom of the riser and a heavy load could crush the riser.
