want to get rid of this ugly "flex" radiator hose
Never liked flex hoses, except in an emergency, but when i was putting my truck together it was quick and easy.
1 1/2" upper hose, stock radiator, with a 5.0L ford.
basically i need a 90 degree elbow thats like 16" long. (its 18" long now)
found a molded silicone hose for like 50-60 bucks.
What have you guys done??
anyone sell 90 degree molded rubber hose ?
I would love to browse thru a local parts store to see if i could find something, but they dont do that around here...
Thanks ! Mark
[IMG][/IMG]
Thanks ! Mark
[IMG][/IMG]
Try this link......open the pdf file in the first post. It is a pretty big file.
Scroll way down, the hoses are listed by size.
Sorry, I don't know how to link it directly.....
Gates Molded hose size guide - THE H.A.M.B.
Many "real" parts stores that cater to pros, especially ones that have been in business for a while are much more accommidating. Try like a Motor Bearing and Parts or a NAPA store to see if they would let you rummage around in their stock after you explain what you are looking for and why. It helps to carry a couple pix of your project and to go in at a slow part of the day. If they do and you find what you need, bring them back a bag of donuts to show your appreciation, they'll likely remember you the next time and be even more helpful.
I agree, make a friend at local parts store, I did and it was a major help. When the truck was running, I brought it over there and they went nuts. Where in CT. do you live? I'm from Bridgeport, Fairfield area. I understand, people up there can be harder to soften up. The Stratfield, Devon, Milford areas are traditional "hot rod" towns, maybe try there. My dad and I bought a Model A coupe in Milford to restore when I was in High School. Good Luck
I went this route:
The local Carquest guy is an old hand and pulled out his hose picture book. I did cheat a little.....I noticed that my son's 66 Mustang with a 5.0 had the right bend arrangement, so I bought that hose and cut it down a little.
I did the same for the bottom:
And....here are the part numbers:
If these don't work, the parts guy did start out with the picture book which shows a pic and states the hose end diameters. He figures that it's easier to start with the book and then start pulling parts for a physical look.
Dan
Dan
I took a wire coat hanger and bent/cut it to the proper length and shape. Then O'Reilley's let me loose in the back. I came away with #2163 Master Pro for the top and #20145 Gates for the bottom. maybe these will work for you? I have a 5.0 SBF with an aftermarket radiator (center outlet at the top and driver's side inlet at the bottom).
fordf348
15
08-29-2018 03:04 PM
bobj49f2
04-16-2008 09:15 PM
