6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Exhaust leak from turbo
Old 03-18-2012, 04:34 PM
bohl345's Avatar
bohl345
bohl345 is offline
I have an 08 job 1 truck that leaks exhaust smoke under the cover that is over the turbo. The problem only occurrs during the regen process, typically towards the end of the cycle. When at a stop light it comes out the hood, the fender side grill and enters the cabin when the heat or ac is on. Two dealers have tried to solve the problem but can never make it occur.
Any insight would be greatly appreciated?
Old 03-18-2012, 04:59 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
they have to do a manual regen and then they will see it.
see the tsb
Exhaust leak in engine compartment:
Some trucks may have an exhaust odor inside or exhaust smoke may be visible around the front. This could be caused by a leak at the turbo outlet from a misaligned downpipe. Verification requires disconnecting the turbo oil supply tubes (replace the banjo sealing washers, W302474) and removing the turbo heat shield to inspect. If the leak is at the turbo outlet, the downpipe will need to be repositioned to seal correctly, with a new downpipe to turbo gasket (7C3Z-6L612-B) and v-band clamp (7C3Z-5A231-AC), and new nuts for the downpipe to catalytic converter flange (W711407-S900). If properly installed, the downpipe will be 11/16" +/- 1/8" from the frame rail. TSB 07-7-7
Old 03-18-2012, 05:43 PM
bohl345's Avatar
bohl345
bohl345 is offline
thanx for the reply.
The truck is going in on tuesday and I will run that tsb by them.
Old 03-18-2012, 10:14 PM
sville6.4's Avatar
sville6.4
sville6.4 is offline
I had this happen to my truck recently. I didn't have any coming back into my cab, my regen just took forever, my mpg's were even worse, and it sounded different. They will have to drop the tranny out to fix it.
Old 03-20-2012, 11:19 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
oops..double post.
Old 03-20-2012, 11:20 AM
golfmedik's Avatar
golfmedik
Mine was a leaky gasket between the turbos and pipes caused by incorrect installation after they had been removed. They found it while in a manual regen and finally seeing the black streaks from the fumes.
Old 03-20-2012, 07:06 PM
ColaMac's Avatar
ColaMac
ColaMac is offline
Got to bring mine in for the same reason. Every regen, I get exhaust smell or raw diesel smell inside of cab.
Rellick
06-19-2014 11:16 AM
shield1978
12-05-2013 03:03 PM
SSSimon
01-04-2011 05:07 AM
John7894
12-28-2009 03:52 PM
sawtooth
12-08-2009 02:06 PM
Quick Reply: Exhaust leak from turbo
